I am trying to place a parts list on a drawing but it is too large for one sheet, so I know I can drag it to the second sheet but then it needs split into three parts to fit and then only two will fit on the second sheet so I want to take the third part to sheet three. How Can I do this?? IT won't let me drag the third part to sheet three, it keeps it as one parts list and won't let it be split up on different sheets.
Solved by Cadmanto. Go to Solution.
There is not a way that I know of to physically seperate the parts list to have one portion on one page and another on a second or third page.
Now, with that said, you can reinsert another parts list on a different page. Maybe the thing to do is on sheet one have items 1-30 and sheet 2 items 31-60 and so on. Is this an option? You can hide the items on each sheet that are not needed so it appears to look like it is broken up.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Yes, I can do it this way but it seems more like a work around rather than the proper way,
Thank you for the help, this will work for me.
Good news is help is on the way. This idea I created some months ago has been accepted.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Ability-to-Seperate-the-Parts-List/idi-p/4383714
Feel free to cast your kudo support for it.
