helloi, i have several models in maya. and i want to use these models in inventor as solid (fill) structure. is there any way to do this?
when i export polygon meshes .iges from maya and import them to inventor there's nothing!
i tried to convert polygon meshes to nurbs surfaces in maya. bu it doesnt work properly. models get disrupt.
also there's a format .stl but i dont know how can i use it between maya and inventor.
Could you please anyone help me?
Welcome to the forum.
Does this link apply to you? Not knowing anything about Maya, based on this article it looks like you need a special plugin to export to iges.
Another thought is Autodesk now owns Maya, so maybe if you do need additional plugins you could contact your local VAR.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You might also want to post this issue on the Maya forum.
I've been doing some work in Alias (2014) this week and - depending on the size of the mesh I import to Inventor, I either get a nice, clean mesh (small mesh size) or absolutely nothing - not even an error message for large meshes.
May be a similar issue. I get the same result in Inventor 2013 and 2014, but if I export the mesh as an STL file it imports to Inventor properly regardless of size.
Could you go into more depth please. I would like to do the same to edit a model I made in Maya through inventor but I can't seem to do it.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
The help page seems to show more filetypes, than are existing in reality.
I couldn't find STL_ATF, INVENTOR_ATF and several other file formats in Maya 2019.1
Walter Holzwarth
Hello @WHolzwarth!
Is the ATF Plugin loaded in Maya?
Here also the workflow exporting with ATF from Maya: Export files with Autodesk Translation Framework (ATF)
Marius
this needs to be loaded in Maya 2019
DarrenP
looking again it looks like stl & inventor file were removed in maya 2019
DarrenP
Niels van der Veer
The Netherlands
Not in many situations, Niels. No result, if Maya data are meshes.
For these cases, I think OBJ is an alternative. But many meshes need reduced number of faces for transfer into an Inventor solid, using the Mesh Enabler App.
Walter Holzwarth
So I installed Maya 2018 and tried to export a file to inventor ATF and Maya says that it exported but I can't find it in its file location where I saved it. I'm going to do some searching on the Maya forms but I just wanted to let yall know.
i also noticed this but i can't say if it ever worked it also could be it broke with the latest update of Maya 2018
& they just eliminated this function in 2019
the stl export from 2018 does create a file
DarrenP
Oh darn. I was trying to learn Maya since I assumed it could import to Inventor...
I'm trying to design a mask on Maya, import it to Inventor, make precise cuts, and lastly 3d print it. Do yall know of any free (or free for students) software that works similar to Maya and is able to export to Inventor to make edits to it?
