I'm using the Simulation Stress Analysis tool that's included with Inventor Ultimate. Is there a way to display the maximum stress location on a part/assembly after the analysis has been run?
Solved by rdyson. Go to Solution.
The Probe/Labels will give you the Max/Min
Thank you, but I'm not sure what you mean. I click on the Probe Labels and it displays the stress value when I click on different locations on the part. However, it isn't showing me explicitly where the maximum stress location is at. I'm wondering if there is a way to display the exact location of the maximum stress without having to rotate the part around and look for it.
