Hello
am looking for a SW 'mates' equivalent.
I can see that i can add restratints (i.e one face in line with, or a set distance from, another) however would like to make two vertices on two parts colinear for instance.
Have tried for AGES to make them colinear.
Thanks for any help, gentlefolk of the forums
Joe
Assuming you're trying to do what I think you are, you can use the Mate constraint, but select edges instead of faces which makes them colinear. If you want them separated by a given distance, you'll probably need to create a workplane or two to restrict the relative movement.
Post a screen shot demonstrating what you're trying to accomplish.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
