I just finished installing Inventor 2012 Premium Suite, I copied the folder "C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data" to a network location and changed my application options to point to this so our engineering team can use the same styles. This was also changed in our project file to point to the same location. I opened a file from The Vault (professional 2012) migrated it saved it and checked it back into the vault. Now the problem I'm having is that after the file was migrated I tried to save the styles to the style library and it gives me an error (see attached pdf). How can I get the style library repaired so that I can update it with our materials that we commonly use?
Solved by sgwilliams. Go to Solution.
Solved by Daniela_Koloszko. Go to Solution.
You can try to resolve the damaged folder by copying again the folder from the default location and then save it to your network location.
The default Design Data folder is stored on your C Drive -> "C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data"
If the Design Data folder is missing from the default location, you can restore the folder by repairing your installation of Inventor 2012. You can find the information for this process in a document on our website. Here is the link:
http://usa.autodesk.com/getdoc/id=TS14938621
Yep that was the answer thanks!
