Inventor Forum
material question
13 REPLIES 13
Message 1 of 14
twr50
1117 Views, 13 Replies
material question
I need to asign concrete as a material to a file. Where can I find it as a material that I can use in Inventor?
Thom
13 REPLIES 13
Message 2 of 14
mcgyvr
in reply to: twr50
You just define a new material style and change its color/texture map to whatever you want.
you can search google images for "concrete" for a texture map if you want
Message 3 of 14
JDMCD
in reply to: twr50
thing i dont like is inventor has a whole ton of different materials to add to parts in the actual part space...however under properties, (physical tab) the list is very small. for example, brass and most other metals and parts are not listed.
Message 4 of 14
JDMather
in reply to: twr50
Textures and material are different things. Textures (colors)can be added to materials.
Message 5 of 14
JDMCD
in reply to: twr50
ok that makes sence, but i think for future inventor programs you should have a wider selection of "materials" to choose from.
i have an assembly that contains an iron casting, a rubber roller, stainless steel spring, a few aluminum pecies as well as a lexan and bakelite insulators. a brass contact. if my boss wants a density and weight report how am i to do this without becoming a chemestry major too?
does this make sence?
Message 6 of 14
mcgyvr
in reply to: twr50
JDMCD
You would simply add all the materials you need into your material styles
Create a new rubber material, create a new cast iron material and so on. Then in the ipt file for each part go into the properties and change it to the new/correct material.
style editor under materials..you can add whatever you want. You don't have to use just what inventor has.
Like they have ABS plastic..but there are thousands of types all with different properties.. So you find those properties and create a new material style.
www.matweb.com has a pretty decent list of physical/electrical/thermal properties for TONS of materials.
Message 7 of 14
in reply to: twr50
As far as Concrete textures go, there are three delivered with Inventor.
They're the same ones delivered with 3ds max.
Bill Bogan | Product Designer - Inventor | Autodesk, Inc.
wrote in message news:5441392@discussion.autodesk.com...
JDMCD
material style.
Message 8 of 14
CAD-One
Has anyone see a video online on how to create a new material from scratch using a matweb data?
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
Message 9 of 14
blair
in reply to: CAD-One
There should be a couple floating around YouTube. I can't attached files to this forum at work but I have a good PDF that I will attached later this evening from my home office.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 10 of 14
mcgyvr
Why do you think it matters where you get the data from?
The process is the same in Inventor no matter if you get it from matweb or the vendors datasheets or your grandpa george..
You just have to convert any data that isn't in the proper units to the units that Inventor is expecting..
Message 11 of 14
mrattray
Note that materials have changed completely since this thread started.
Mike (not Matt) Rattray
Message 12 of 14
CAD-One
in reply to: mcgyvr
We always refer to matweb as opposed to any other. Its just a reliable & popular source. May be downthe line when we can really need & afford, we can but their CAD/FEA export too.
C1
AutoCAD 2020
Message 13 of 14
blair
in reply to: twr50
this document should help.
Delta Tau Chi ΔΤΧ
Message 14 of 14
CAD-One
in reply to: blair
Thanks for this great resource.
C1
AutoCAD 2020
