Hello, I've got a question about the key generating function in inventor.
I'm trying to design some keys in a shaft for a project in working on. In that design the steel alloy I'm using is important so that the design doesn't fail. The only problem is Inventor uses some unit called "Allowable Pressure" to perform this calculation. All the material data sheets I've looked at don't have a material property by that name. Is this a material property or perhaps something else?
Any help would be appreciated.
Are you checking the materials box and customizing the material?
The allowable pressure is based off of the ultimate yield strength. You would never want this to be equal to the UTS because of unknows. (its a safety factor).
Kirk
