I am using inventor 2012 but the material library is not loading.
Then i go to the Manage> Styles Editor> and clieck on color or material it only gives me the option of defualt.
The drop down box in the top right is greyed out so i cannot change this either.
It works fine on another PC just not mine.
I have downloaded the material pack from the website also.
I have also changed the hardware settings. I have tried all 3 hardware settings and it makes no differance.
Running windows 7 x64, 8 gigs of ram 3.4 quad core, 128gig SSD.
Everything is up to date.
When i installed the material library download the material library was working, but when i opened a file the material library went back to how it was above.
The files i am using are from models i made in inventor 2010, but there is no problem on another PC i use.
Any help would be great.
Are you pointing at the right project?
With no file open, Get Started Tab, click projects.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
In case you are a visual find of guy.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for the replies, however i still not sure what to do 😞
I am sure you have guessed i am not the person who uses autocad lol. I am just trying to help out a friend.
I have done as showen, and it shows a list of differant projects, but now i do not know what to do. So sorry for being such a noob.
Thanks again for all your help.
