I am trying to work out the most efficient way to produce a drawing that contains a cutting list showing Section Width, Thickness and Length for each component. i am currently producing a part then using the manage tab - make components to generate an assembly so that the components appear in a BOM. If i open the individual part from the assembly, the root of the part is shown under the derived part. It is prefixed with a grey circle surrounding a +sign. If i hover over it an indicative volumn appears on my screen which contains all of the information that i am looking for ie. Overall Section Width, Thickness and Length.
The information must be calculated to produce the graphic, does any one know i i can tranfser it dirwctly into a cutting list on a drawing?
