For the holes to line-up, the pitch of the holes in the bottom flange MUST
be different from the pitch of the top flange.
But the SkeletonPart is using the "common" line between the parts, the line
where the holes must line-up, so you will automatic get your correction
factor.
You can't specify one pitch which both flanges will use.
T. Ham
Mechanical Engineer
CDS Engineering BV
Dual Pentium XEON 2.2 Ghz
2 GB SDRAM
NVIDIA QUADRO4 700 XGL (Driver = 77.18)
18 GB SEAGATE SCSI Hard Disc
3Com Gigabit NIC
Windows 2000 Professional SP4
Autodesk Inventor Series 9 SP4
Autodesk Inventor Series 10 SP3a
wrote in message news:5103499@discussion.autodesk.com...
Teun,
Thank you for your response which I have now looked at.
Unfortunately, my constraints are that the end holes are 150mm in from each
end and the remaining distance is filled with holes at 150mm pitch from one
end plus a makeup pitch.
As has been pointed out, I need to apply a correction factor to the pitching
on the curve, plus a bit for the top flange, minus a bit for the bottom
flange, so when you put them together the holes line up to get the bolt
through. (although as a steel erector once told me years ago, "boy, if you
can see daylight you can get a bolt through!")
I have a method but it's a bit of a pain and I can't integrate it to
automatically change when I change the master sketch. But I'm not giving up
yet .....
