Hello all,
I start with top-down modeling in Inventor and I would like to ask you for couple of advice or clarifications:
1) In case I make a master sketch (.ipt) for big assembly, how should I organize the browser where I have lot of sketches, work planes and surfaces....can I make some root system there.....e.g. sub-master sketches in the master sketch browser?
It looks like very chaotic if I put all these working features in same level.
2) Is there a way how can I put once made master sketch for a part into the assembly master sketch which I am going to do?
For example: I have a parametric master skecth for Part X as well as for Part Y and these I would like to use in the parametric master sketch for the Assembly XY.
3) In case I have same parts (sketches) in the master sketch...should I make sketch in the master sketch for each part?
I have started with Inventor just 5 weeks ago so I am not familiar with all functions.
Thank you for your help, Vlada
Hi Vlada,
Depending on the number of parts the Multibody parts could be a good solution for your case. You can get an overview at:
http://synergiscadblog.com/2014/07/29/inventor-multi-body-part-modeling-part-1-of-2/
Best regards
