Show only
Search instead for
Got it ... thanks Kent. Add-ins are cool ... even I can get them to work!
~Larry
"Kent Keller" wrote in message
news:1F702FDD65FAA8D5B434291FE79DD34B@in.WebX.maYIadrTaRb...
> I have posted a Insert and Fix Addin to my Icode page for anyone that
likes
> to work with Master Sketches.
> http://www.mymcad.com/kwik/iCode/icode.htm
> It has the ability to sort the files before inserting which I find nice
> since we lost the ability to reorder in the browser. 8^)
> Hope someone finds it useful. 8^)
> Kent Keller
> Member of the Autodesk Discussion Forum Moderator Program
> http://www.MyMcad.com/KWiK/Mcad.htm
doesn't seem to work (jet?) I get an error during instalation probably because there is something wrong with the vbalIml6.oca. It is placed like this in the macro directory. Shouldn't it be vbalIml6.ocx?
I installed your add-in without errors, but when I click on the add-in and no dialog box appears. I checked, it shows startup/loaded in the add-in manager.
I had one tester install not work and 4 that did. I never was able to
determine the reason it didn't work at the one, but maybe your hint about
the oca ~ ocx might be the key. Most of the testers that it worked for
could have had that ocx already registered from something else.
I will let you know as soon as I get a chance to check it out. Thanks for
the feedback.
Kent Keller
"rspaargaren" wrote in message
news:f142b9d.1@WebX.maYIadrTaRb...
> richard
My apologies to the people that downloaded the program and it didn't work
for them.
Thanks to Richard we found the problem, I had added vbalIml6.oca instead of
vbalIml6.ocx to the install program.
Anyone that got it and it worked, there is no need to redownload it, but if
you got it and it didn't work, hopefully I got it right this time and you
should re download and install it.
Kent Keller
