i would like to know if you can manipulate views in idw files
i am doing a casting drawing which i can create and dimesnions np.
now i would like to make a maching drawing from that same model.
i go back to ipt file and create a view and call it machining .which i make current . i create my sketch and extrude my .060 machining
now when i go back to my casting idw. i show the machining part of it. which is not what i want.
can a operation be suppressed by a niew. master view that machining extrusion be suppressed. machining view unsuppressed?
what am i missing?
bob c .
Solved by JDMather. Go to Solution.
The best way to do this is to start a new part file and Derive Component the original into the new.
Yes.
