It doesn't happen very often (apparently, 8 days ago was the last time), but I would like to know more about this error.
The .png I've attached shows what happens more easily than I can describe it.
It only happens on Part1 (and possible Assembly1?). If I've made a new part and the menu loaded correctly, it won't load improperly on a later new part (, like Part2, Part 3, etc). It does not happen saved parts that I open. If I have other files open when this happens, the Manage menu seems to be correct in any file, but Part1. Closing IV and reopening has fixed it every time, but one. The time closing/reopening IV didn't fix it, I closed it again, and reloding IV again, the menu was fine.
The visible portions of the buttons work correctly, but the empty spaces where the icons for the button should appear, do nothing.
No other tab has done this.
Thoughts?
Solved by JDMather. Go to Solution.
Have you installed Update 2 for Inventor?
Update your graphics driver to the latest version: http://www.nvidia.com/object/quadro-tesla-win8-win7-winvista-64bit-305.93-whql-driver.html
Thank you, and no I have not.
Back in July, I was invited to enroll in SP1 beta from Autodesk. I havne't updated anything IV since.
Click here 3 times (or whatever).
