Inventor Forum
Manage Tab doesn't load correctly
7 REPLIES 7
Message 1 of 8
853 Views, 7 Replies
It doesn't happen very often (apparently, 8 days ago was the last time), but I would like to know more about this error.
The .png I've attached shows what happens more easily than I can describe it.
It only happens on Part1 (and possible Assembly1?).  If I've made a new part and the menu loaded correctly, it won't load improperly on a later new part (, like Part2, Part 3, etc).  It does not happen saved parts that I open.  If I have other files open when this happens, the Manage menu seems to be correct in any file, but Part1.  Closing IV and reopening has fixed it every time, but one.  The time closing/reopening IV didn't fix it, I closed it again, and reloding IV again, the menu was fine.
The visible portions of the buttons work correctly, but the empty spaces where the icons for the button should appear, do nothing.
No other tab has done this.
Thoughts?
7 REPLIES 7
Message 2 of 8
Do have the updates loaded?
Post your system specs, graphics card, etc.
Message 3 of 8
What other info would help?
Message 4 of 8
Have you installed Update 2 for Inventor?
Update your graphics driver to the latest version: http://www.nvidia.com/object/quadro-tesla-win8-win7-winvista-64bit-305.93-whql-driver.html
Message 5 of 8
Thank you, and no I have not.
Back in July, I was invited to enroll in SP1 beta from Autodesk.  I havne't updated anything IV since.
Message 6 of 8
JDMather
Click here 3 times (or whatever).
Message 7 of 8
theo.bot
I have THE Same problem, i always solve this by turning off and on the panel text
Message 8 of 8
RobJV
Same problem here while working on a a part in the context of an assembly - thanks to JD for workaround.
Rob
