Inventor Forum
Making parts of an assembly invisible in some idw views : Not working in 2012.
2 REPLIES 2
LawrenceFHoughton
2064 Views, 2 Replies
Because of the disparity in size of some components I need to make parts of an assembly invisible.
The last time I did this was last Monday in IV2011. Tuesday I loaded IV2012. I have drawn the same parts in 2012 and now I cannot do it. "Visibility" is grayed out in the browser.
Why is this? Bug or setting?
... LFH
2 REPLIES 2
mcgyvr
in reply to: LawrenceFHoughton
See attached.. Uncheck it if you want to be able to control visibility in the IDW.. Check it if you want visibility to be controlled via a design view rep in the assembly.. Been this way since 2009 I believe.
LawrenceFHoughton
in reply to: mcgyvr
Thankyou. Problem solved.
