Inventor Forum
Making Parts in an assembly act solid
3 REPLIES 3
5347 Views, 3 Replies
I need to make two parts act solid.  That is, that they need to slide and react as if they were real instead of just going through eachother.  In the assembly included, the "rotator" needs to rotate as it is pulled through the "rifled column (2)".  The other constraints in the assembly are fine as is, but if I can make these parts react correctly, then the center pole and balde will rotate.
3 REPLIES 3
Curtis_Waguespack
JDMather
Your attachments missing a bunch of parts - most imortantantly, the Grounded part shield.ipt
JDMather
in reply to: JDMather
Make sure Activate Contact Solver is turned on on Inspection tab.
Right click on the Drive This constraint and click Play.
(see attached assembly)
