Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 17
Making line configurations closed shapes for extrusion?
1655 Views, 16 Replies
03-07-2011 03:33 PM
I just completed a sketch for a simple part I'm working on. It contains some arcs, lines, and rectangles that I've drawn. When I went to extrude them to make the sketch 3D, not all of the shapes I created could be extruded, presumably because in my sketch the lines/arcs did not come together properly to create a closed shape.
How do I fix this?
Well, it wasn't missing coincident constraints - it was mainly geometry that was not sketched well. By that I mean:
-The long arcs on both sides extend past where they should intersect the line and needed to be triimmed back the intersection with the straight line.
-One of the long arcs had a duplicate sketched on top which needed to be deleted.
-Some of the geometry didn't actually extend far enough and had a gap etc.
Also, with the symmetry of this sketch, I would create one half and then mirror the duplicated portions. That keeps things that could go wrong to a minimum.
I've attached the cleaned up geometry that will extrude (R2011), but the best advice to keep this from happening again is to make sure you have a clean, well modeled sketch. The green dot when you are sketching is your best friend. It means you have a clean termination and coincident constraint.
Best regards,
Paul
Employee
11 Kudos
Post 2 of 17
Re: Making line configurations closed shapes for extrusion?
03-07-2011 04:29 PM in reply to: sciguy77
Inventor determines closed shapes by finding all the coincident loops. I would need your actual geometry to troubleshoot. However, if you turn on the constraint display, you can see if you are missing coincident constraints at intersections that should form a closed loop and add them manually.
Best regards,
Paul
Paul Normand
Principal Content Developer/SME
Design Lifecycle and Simulation (DLS)
Active Contributor
0 Kudos
Post 3 of 17
03-07-2011 05:24 PM in reply to: Paul.Normand
I've attached the .ipt, as you can see its very simple sketch, but hey, we've all got to start somewhere, right?
I tried manually adding a closed loop, but got a "too many constraints" error. How can I fix this?
Thanks!
*Pro
40 Kudos
Post 4 of 17
03-07-2011 05:53 PM in reply to: sciguy77
This is not a simple sketch. Time to lose the AutoCAD habits and create multiple features from this geiometry.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Employee
11 Kudos
Post 5 of 17
03-07-2011 05:54 PM in reply to: sciguy77
Best regards,
Paul
Paul Normand
Active Contributor
0 Kudos
Post 6 of 17
03-07-2011 06:46 PM in reply to: Paul.Normand
Thanks a million Paul, that was really helpful.
Yes, it was sketched poorly, that was my 1st sketch ever (never even used AutoCAD). Thanks for understanding and helping me out. :smileyhappy:
1,708 Kudos
Post 7 of 17
03-07-2011 09:10 PM in reply to: sciguy77
Hi sciguy77,
I addressed the issue of simple sketches in a recent blog entry. Have a look, and give the suggested method some study, and then I'm certain you'll find sketching in Inventor to be more friendly going forward.
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
2,132 Kudos
Post 8 of 17
03-08-2011 03:12 AM in reply to: sciguy77
sciguy77 wrote:
.... that was my 1st sketch ever....
You might also read this document.    http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
0 Kudos
Post 9 of 17
Extrude a projected 3D curve
02-10-2012 03:24 AM in reply to: sciguy77
Dear everyone,
How can I extrude a line which is a 3D sketch that I used the command "project to surface"?  Can Inventor do this?
2,132 Kudos
Post 10 of 17
Re: Extrude a projected 3D curve
02-10-2012 04:58 AM in reply to: teresa
Instead of projectomg to that surface - why didn't you simply extrude to that surface.
That is exactly what you are requesting, but done in the logical order and fewer steps.
Attach your file here.
