Inventor Forum
Making holes on a cylander
5 REPLIES 5
Drtaylor
359 Views, 5 Replies
I am trying to Drill a series of holes on a cylander. I cannot find out how to start the sketch on this surface so that i can drill on the rounded part of the cylander.
5 REPLIES 5
in reply to: Drtaylor
Make a tangent workplane to start your sketch on. If you don't know how, click on the workplane icon and hit F1... there are some pretty good sample~tutorials. -- Kent Assistant Moderator Autodesk Discussion Forum Moderator Program "Drtaylor" wrote in message news:17223121.1076702055155.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to Drill a series of holes on a cylander. I cannot find out how to start the sketch on this surface so that i can drill on the rounded part of the cylander.
You can not sketch on the cylinder, as Kent says, you either need to create a plane (possibly tangent to your cylinder) or sketch on one of the default planes.
g.desbrisay
Been trying this over and over, but cannot figure out how to create a tangent work plane.  My copy of Inventor 2013 running in Windows in Parallels on a Mac does not behave at all like the tutorials.
Any guidance?
JDMather
in reply to: g.desbrisay
Post screen shots
1. Expanded origin in browser
2. Workplane tool active
3. One of the two planes that go through the axis of the cylinder selected (this assumes you create the cylander at the origin)
4. Side of cylinder selected.
Tags (1)
g.desbrisay
in reply to: JDMather
That worked.  Thanks!!
To create a hole in a cylinder you first have to create a workplane that is tangent to the cylinder:
     In the browser, expand the Origin, and choose a plane like the XY plane or the YZ plane,
     Select the workplane tool
     Select the cylinder,
     and then a workplane will appear that is tangent to the cylinder and parallel to the plane that
     was choosen previously (this creates a workplane that is "tangent to surface and parallel to plane").
Once you have that new workplane you can now create a hole in the cylinder:
     Select that plane by clicking on one of its edges,
     enter sketch mode,
     place a point on the workplane where you want the hole in the cylinder,
     finish sketch mode,
     choose the hole tool,
     and create a hole starting at the point you created!
Thanks again!
Greg
