Inventor Forum
making frame -frame generator or solid modelling
5 REPLIES 5
lougalea
300 Views, 5 Replies
I am needing to make a frame for a machine as for demonstration purposes...as this is for presentation would you still recommend using the Frame Generator or would Solid Modelling tools be just as good
Lou
5 REPLIES 5
cbenner
in reply to: lougalea
Well, I usually say Frame Generator, but it does have a learning curve to it.  How much time do you have?  FG will give you much more accurate frames in terms of end conditions, coping and trimming etc. I would never go back to building frames with standard assembly methods.
blair
It would depend on what types of items are going to make up the frame. If the majority of the F-G can be done with CC items, then the F-G would be my first choice.
If I had to build a frame from built-up beams (vary in depth and width of each beam) then just use the solid modeling.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
cbenner
in reply to: blair
Years back the guys here built their frames from i-features.  They had a library of steel profiles, and another for the notch cuts.  What a pain.  Fortunately I came in just as AD released the frame generator!
blair
in reply to: cbenner
Before that, Drafting machines, they didn't require: Saving, Updates, Hot-Fixes, Re-booting or Tech Support, or EE's.  Smiley LOL
Delta Tau Chi ΔΤΧ
Frame generator. It will take you about 10 minutes to learn to use it, and another lifetime to master :), but seriously, it's the only way to go, beats stick building hands down.
The basics:
http://www.youtube.com/watch?v=0QvkY6afCWg
http://www.youtube.com/watch?v=wNIkbWXX1N8
