Inventor General Discussion
0 Kudos
Post 1 of 8
Making bent tubes using Bend Part.
3298 Views, 7 Replies
10-28-2010 12:33 PM
Is there a way to adjust the stretch in a part when using Bend Part. Similar to a bend table in sheetmetal. I'm creating a bent hydraulic tube from a straight tube. The finished part comes up a little short in total length. See attached.
*Expert Elite*
2,131 Kudos
Post 2 of 8
Re: Making bent tubes using Bend Part.
10-28-2010 12:38 PM in reply to: gkawkes
I would not use Bend Part for something like that (Bend Part should be very very rarely used, only when no other way).
I create 2D sketches to control a 3D sketch Sweep path.  All of your dimensions (except bend radius) in the 2d sketches.  The part is designed "as bent" so you know it is right without any calculations.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 3 of 8
10-28-2010 12:52 PM in reply to: JDMather
I'm assuming the answer is No. That there is no Bend Table type option for Bend Part. I'm only doing it this way to check my calculations, not to use it for the final part.
*Expert Elite*
2,131 Kudos
Post 4 of 8
10-28-2010 12:59 PM in reply to: gkawkes
Someone years ago showed a work-around modeling as square profile sheet metal (solid, not tube) with fillets making it appear round.  Might be able to adjust bend allowance to give useful results.
**Master
43 Kudos
Post 5 of 8
10-28-2010 01:12 PM in reply to: gkawkes
For what it's worth: in my experince with having parts such as this rolled/formed, generally these things are done by adding length (say 6 inches or so for each end) to the finished length and then cutting to length once rolled. You might consider following the "model it the way it's made" mantra here and add ample length to the straight shape, and then use the move face tool (or extrude cut, or thicken cut) to arrive at the finished size once bent.
Just a thought.
*Pro
40 Kudos
Post 6 of 8
10-28-2010 01:35 PM in reply to: gkawkes
Actually you can simulate the bend allowance by positioning the bend line into the part.  Let's assume that to want to utilize a K factor like .44. That would equate to positioning the bend line sketch 44% below the top of the tube face.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Member
0 Kudos
Post 7 of 8
03-11-2011 10:30 AM in reply to: JDMather
Why should the bend part feature be used rarely?  Is there any way to flatten/straighten the tube after generating it using a series of 2D sketches combined with a 3D sketch?
*Expert Elite*
50 Kudos
Post 8 of 8
03-12-2011 12:49 AM in reply to: gkawkes
If the tube has simple bends on one plane you can include the bend sketch on your drawing to workaround a flat pattern.
You will need to hide the bent edges of the model on the drawing and show the projected edges of the bend sketch.
You will also need to draw over the projected edges on the model bend sketch to allow them to show on the drawing.
The more features and bends in different planes then it gets tricky/impossible.
Another way is to have one part as flat/unbent and a second part which is derived from the first then bent, this maybe a simpler option.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
