I have an assembly (ex: test1.iam) that have many parts.
There are 2 of them, that I what to make only one assembly, and I would like them to stay in same the position as in test1.iam.
How do I do that?
Sophie
Solved by psp. Go to Solution.
1. Highlight the two components. (i.e. press control and then click once on each of the components)
2. Press "TAB" on the keyboard - this starts the command Demote which will prompt you for a filename.
