Inventor Forum
Making a wing rib in sheet metal
6 REPLIES 6
rkirk77
2797 Views, 6 Replies
Hi There,
I am new to Inventor and I ahve been trying to creat a wing rib similar to the one in the picture.  I have been successful in recreating the basic shape itself, but I cannot figure out how to make the bend to the "lightening hole" (circle).
Any help would be seriously appreciated...
Windows 8.1 Pro 64-bit
Intel i7 870 @ 2.93 GHz
Nvidia GeForce 580 GTX 1536MB GDDR5
8 GB Ram
250GB HDD
6 REPLIES 6
JDMather
in reply to: rkirk77
Attach the ipt file of what you have attempted so far - or at least indicate what version of Inventor you are using.
Do you need a sheet metal part that will give Flat Pattern - in that case look into Punch features.
otherwise - looks like a simple countersink and shell feature.
rkirk77
in reply to: JDMather
I am using Inventor 2014
What i am trying to do is make this model so I can flatten it out and use it for a template for cutting out a new wing rib.  I will be doing this with a bunch of other ribs as well, so I really haven't saved any files thus far as I am trying to learn the workflow.
8 GB Ram
250GB HDD
JDMather
When you do save a file - attach it here for pointers.
You might go through these -
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
rkirk77
I made a quick example file for how the wing rib would look.
8 GB Ram
250GB HDD
rkirk77
Attached file is above.
8 GB Ram
250GB HDD
Chris1969
You could make a punch that created the countersunk hole.
It's not really very intuitive to do, but you can seach google for a tutorial.
But creating it as a solid and then "shelling" would also work.
Brgds,
Chris
