Hi I made 2 pipes in cad and now i trye to veld it together
I put the pipes togeter the longway so it loks like an 8 from the end and now i want to weld it in the v betvine the pipes
Put i cant get Inventor to understand it is an surface...
The end of the pipe is ok but the side of pipe
Any good Tip how to get it to be a surface that i can weld and scetch on .....
Regards
Ac
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Trye agen
I miss one futer that i have befor on old version it vas somthing like make copy to one directory whit all file that vas in the asambly
Dont remember exaktly the name of ot ..
Regards
Ac
You may need to split faces.
How large do you want the weld bead?
Have you installed Service Pack 1 and Update 3?
