Inventor Forum
MAKE VIEW PRECISE
4 REPLIES 4
226 Views, 4 Replies
MAKE VIEW PRECISE
All of a sudden when i print i get an alert that says " some of the views on the following sheets are not precise. printed drawing may have inconsistencies. to make views precise, select "make views precise from the view context menu. Does anyone know where the view context menu is?
4 REPLIES 4
RMB on the view label in the browser. That will bring up the view context menu. Greg Willard wrote: > All of a sudden when i print i get an alert that says " some of the views on > the following sheets are not precise. > printed drawing may have inconsistencies. to make views precise, select > "make views precise from the view context menu. > > Does anyone know where the view context menu is? > > -- Hal Gwin Mechanical Designer Xenogen W2K SP4 Dell Precision 650 Dual 2.66 GHz Xeon 1.5 GB DDR Quadro4 900 XGL nVidia 6.14.10.4472 w/registry update Dell UltraSharp 19" LCD
still at a loss. "Hal Gwin" wrote in message news:4015478d$1_3@newsprd01... > RMB on the view label in the browser. That will bring up the view > context menu. > > > Greg Willard wrote: > > > All of a sudden when i print i get an alert that says " some of the views on > > the following sheets are not precise. > > printed drawing may have inconsistencies. to make views precise, select > > "make views precise from the view context menu. > > > > Does anyone know where the view context menu is? > > > > > > -- > Hal Gwin > Mechanical Designer > Xenogen > > W2K SP4 > Dell Precision 650 > Dual 2.66 GHz Xeon > 1.5 GB DDR > Quadro4 900 XGL > nVidia 6.14.10.4472 w/registry update > Dell UltraSharp 19" LCD >
We have that happen with larger assemblies. Based on processor speed and other applications running, it may take up to 30 minutes for us on 1000+ part assemblies to generate precise views. It's worse with smaller scales. Try putting different views on different sheets in larger scale. That may help.
Check the Task Manager, you'll see the processor going at 100%.
Good luck !
I have seen this many times, especially if the drawing contains a spring (or helical feature). When you RMB to get the menu, the "make view precise" option is missing. It seems that IV has a real problem with spiral/helical features and one can only hope theat R8 is better.
