How do I make a style in the library standard?
I made new styles in the library for a revision table and parts list, but when placing them in an IDW I always get the standard tables.
It's not a big deal to change it in the format tab after placement, but when having 50+ sheets/daily its getting annoying.
Berry
Solved by karthur1. Go to Solution.
Open an idw. Go to the Manage tab, Styles editor. Select the standard you are working with. Now go to the Objects default node and expand it. On the right side, find the Revision Table Object type and select the object style you want.
Save it and exit.
Forgot to mention, that in order to save it, you have to have Read/Write access to the library. At the top of the Styles and Standard editor window, it will say either "Library-Read Only" or "Library-Read/Write".
