Inventor Forum
Make style standard
2 REPLIES 2
berry.lejeune
323 Views, 2 Replies
Make style standard
How do I make a style in the library standard?
I made new styles in the library for a revision table and parts list, but when placing them in an IDW I always get the standard tables.
It's not a big deal to change it in the format tab after placement, but when having 50+ sheets/daily its getting annoying.
Berry
2 REPLIES 2
karthur1
in reply to: berry.lejeune
Open an idw. Go to the Manage tab, Styles editor.  Select the standard you are working with.  Now go to the Objects default node and expand it.  On the right side, find the Revision Table Object type and select the object style you want.
Save it and exit.
Forgot to mention, that in order to save it, you have to have Read/Write access to the library.  At the top of the Styles and Standard editor window, it will say either "Library-Read Only" or "Library-Read/Write".
Dennis_Buss
in reply to: karthur1
Thanks!!!!
