I am on inventor 2013...My make components command stopped working I know I have used it in tha past.
After I hit next on the first screen nothing happens, it just brings me back to the part I can zoom in and out or do any other command....If I right click I have the options for Ok, Apply and cancel.
If I hit either apply or ok, I will get a dialogue box say, "default template could not be found"
If I just create a simple part with two bodies, I get the same problem.
I am able to open a new template throgh the new file window, or by the shorcut in the ribbon?
any ideas before I try a complete re-install
Solved by JDMather. Go to Solution.
Just to be sure -
can you attach screen shot like this
I see Standard (in).ipt, not Standard.ipt
Are you clicking directly on 1
or
are you clicking on 2 first and selecting a template?
