Hi, does anyone could give me some suggestions on how to make the 2D barcode Data Matrix barcode in Photoshop CS4?
Solved by Frank964. Go to Solution.
Solved by mcgyvr. Go to Solution.
I suggest you post this question in a photoshop cs4 forum
A barcode font may help you. Once you installed it in your PC, any application using fonts can generate barcodes as a font.
Do you need a bar code for the IDW? If so I have one I made years ago I will see if I can locate it if you like...
http://www.lmgtfy.com/?q=photoshop+cs4+2d+barcode
I tried linear barcode in Photoshop CS6. It works well until now. I am using linear barcode font. You may search a 2D one.
Data Matrix has a little more complex algorithem than linear barcode. So it is difficult to draw it manually. A better way is to use a font to create it in your application. This Data Matrix font shows a details
Hello, I have seen the barcode font you recommended, but it is chargeable. Is there any free version for me to use? I don`t want to buy one.
font is one way to go, i think Data Matrix barcode plugin can help you generate barcodes in various image formtas. also it rotate, resize data mode and so on. here is a free trial i foud, why don't you give a try.
@Ian_56 wrote:Hi, does anyone could give me some suggestions on how to make the 2D barcode Data Matrix barcode in Photoshop CS4?
go to google for a guide to generate data matrix
