Inventor Forum
Make a hole in a SPHERE
5 REPLIES 5
KobieR
6859 Views, 5 Replies
I am making a pair of legs (kinda like a little action figure legs) and am tryinmg to make a joint. i wanted to use a sphere as part of the rotation but need to put a hole in it. How can i put a hole in it, i feel like ive tried everything! thanks guys 🙂
5 REPLIES 5
CCarreiras
in reply to: KobieR
Hi!!
Make a sketch and extrude it with the following definitions.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
KobieR
in reply to: CCarreiras
Do I do this off of a 3D sphere? The freeform, or is this on a sketch?
CCarreiras
in reply to: KobieR
Hi!
In the image: It's a sphere + sketch on the sphere's center plane with a circle on it  + extrusion cut.
It's a lot easier if you show us what you need to create.
Have you a sketch or sheme or foto to demonstrate what you trying to build?
CCarreiras
KobieR
Thank you, I got it! that's exactly what I needed. thanks 😄
Callesson
in reply to: KobieR
Not a sphere but same procedure.
If you know how to work with planes, this is also how you can do it.
I know its not exactly your part but I thought you might want a video. ( And its was the closest I could find, hope it helps)
Atleast more flesh on the bones 🙂
https://www.youtube.com/watch?v=2Tr7qBb6iqk&feature=player_detailpage#t=137
Autodesk Inventor 2015 User
