Hi
I have a problem with updating assemblies and parts. For example, I have put a few holes into a plate in my main assembly. But when i open my part assembly these holes cant be seen nor in the part it self. Is there anyway of updating this so these holes cant be seen in the part assembly and the part its self ?
Willie
Solved by JDMather. Go to Solution.
In efffect, you have "match machined", that is - drilled the holes after the parts are assembled.
The result is exactly the same as the real world result.
You can edit a part while in an assembly to place the holes at the part level rather than at the assembly level.
Since you have already done the holes incorrectly - at the assembly level - search the App store for an add-in to push them to the part.
