Hi All,
I made a title block from scratch, and I save it to templates. The problem is when I open a new drawing and go to look at my templates in drawing resources it is not there. What am I overlooking? Any help would be appreciated. I'm sure it's something simple. Thanks.
Tyler
Billa
Welcome to the community...
First I would look at your new dialog box.. What path does it state at the top? Is it the same location where you put your template? If not then look at your applications options/file tab and also your current Inventor project file. Where does the template folder point to? Remember if the template location in your project file states default than application option takes control. If its not default then project file is in control where the templates are.
Also what version of Inventor are you using?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Did you save that template ... or make that title block in your default template.
If not... that's ok. Open the file that has the new title block and go to your Resources ,copy it out ..and paste it into the titleblock folder of the template default.
Make sure you're saving it into the default templates for it to always be there.
Whenever I go to paste the title block into default template, I cannot find the Title Block Folder that you are speaking of. Do I need to Save my whole drawing into that folder?
You can ...
If you open the file that has the new template ....
go to the Title folder and copy it ...
Paste it in the new
if you need to ...you might have to replace it if you have it as the same name as the default on. I would recommend editing it, so you can save it as a new name
