Inventor Forum
Macros / VBA Editor button not working
21 REPLIES 21
Message 1 of 22
CadUser46
3939 Views, 21 Replies
I have a users machine that is displaying some odd behaviour.  Their Macros and VBA Editor buttons have stopped working.  We have tried several things already but nothing appears to have any effect.
Any suggestions?
Inventor 2010 Certified Professional
Currently using 2023 Pro
21 REPLIES 21
Message 2 of 22
CadUser46
in reply to: CadUser46
Here is an update of the behaviour from my colleague;  (Worth noting we are using our own project file and have the App Options pointing to a local server where the edited Default.ivb sits).
IT did a reinstall on pc but it still doesn’t work.
I tested it on another new win7 pc and it had the same problem.
We’re a bit at a lost, because there seems to be no structure here.
I’ve checked with all new win7 machines that are in use now, of which 4 work ok, 6 not.
On the win7 test machine I got te message from the attached screen print.
If I try to do macro when I have a part open I get nothing
If I try to do macro when I have a drawing open I get this message:
And then nothing.
If I try to do macro with no file open I do get the macro window,
If I do VBA editor I get the editor but it says “no project”, even if I open a file which has code in it.
Message 3 of 22
CadUser46
Anyone care to take a punt at this one?
Message 4 of 22
Can we assume that all Win7 systems had Inventor installed using these instructions?
http://teknigroup.com/support/InstallAdsksoftware.html
Message 5 of 22
CadUser46
Ah, no Dennis we cannot assume that.  We are subject to corporate IT and i doubt all of the items would have tick beside them.  I shall pass it on.
I would like to assume however that all the installations were done in the same way and majority of them are working including my own.  For the sake of a solution though i will ask them to re-do one machine as per the link and will report back.
Thanks.
Message 6 of 22
CadUser46
Without getting into other things this problem has still not been resolved.  There is no project loaded in the VBA editor.  I managed to find one other example of this on the web where a persons Outlook vbaproject.otm file had been corrupted.
I did a search but cannot find this file on the mahchines.  Is there an equivalent file that somehow controls the vba window for Inventor?
Message 7 of 22
CadUser46
Really want to avoid imaging this machine.  Is no-one willing to even take a guess?
Message 8 of 22
ACEDeSmedt
We have the same problem. VBA Editor and VBA not working on a win7-64bit machine. Found a solution yet?
Klaas De Smedt
If this is the solution, push the solution button 😉 (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
Message 9 of 22
CadUser46
in reply to: ACEDeSmedt
Hi.  No solution yet.  I have been through many more things that i have not listed here.  Also Rocky has posted a few times on another thread i have in the customization forum.
Message 10 of 22
Ray_Feiler
Have you tried coping the Default.ivb to "C:\Program Files\Autodesk\Inventor 20XX\bin\Macros" and updated your App Options?
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 11 of 22
karthur1
I was working on one of our workstations the other day and could not get a macro to run (using Inv 2011).  Tried to start VBA editor to see if it was even loading and the editor would not start.  Reboot didnt help.  So I turned off the UAC and did a repair installl.  Rebooted and it started working then.
I ma sure you have done all of that, but that is what worked for me.
Message 12 of 22
CadUser46
in reply to: karthur1
Hi.  We had already uninstalled/reinatelled once but i tried repairing again for good measure.  Still not working though.
Message 13 of 22
NielsMaas
Anyone?
We are experiencing the same problem here.
System:
Windows Vista 64bit (SP2)
Inventor 2012 (Premium)
Message 14 of 22
ACEDeSmedt
in reply to: NielsMaas
Today I found the solution of the VBA mystery.
My plan of attack:
I noticed the only difference with other computers where the VBA module worked was the installation of Inventor 2011 (This is not the cause of the problem). So i did on the problem computer.
Whet running the VBA in Inventor 2011 I got the following error:
object library invalid or contains references to object definitions that could not be found
Google told me something of activeX and cash files. In short, you have to delete all the activeX cashfiles to solve the problem so i did. After that, VBA worked again in 2011 and 2012.
How to remove activeX cash files:
 open the command window (cmd.exe) and type:
cd c:\
DEL /S /A:H /A:-H *.EXD
Essentially the command recursively deletes all your hidden and exposed exds. That will make all your activeX components load a bit slower the first time you use them again, but it should also clear out the problematic ones.
regards,
Klaas De Smedt
Message 15 of 22
NielsMaas
It's solved here!
But I can't say it's whether because of clearing the cashfiles or installing the SP1 for Inventor 2012 (I did both).
So Klaas I would say half a kudo!!
Message 16 of 22
ACEDeSmedt
Installing the SP1 did not work for me and for Inventor 2011 so i must be the cashfiles 😉
Message 17 of 22
Same Problem here..
Inventor 2014 (came with FDS2014), VBA Editor /MAcros button is not working.
Load VBA on start-up is not available in Application Options.
Can somebody point out me in right direction.
AD
Message 18 of 22
jozef.dubaj
With 2014 there was a different issue. Most probably your VBA 7.1 was not installed correctly
Please take a look here
Greets,
Jozef
Message 19 of 22
in reply to: jozef.dubaj
Found the solution by myself. It is Here.
Thanks for reply..
Message 20 of 22
this software the support is very lousy.
also select the very expensive parking place for seminal,
when I make a complaint .  staff from Autodesk ask me to  take  public transport.  Them  funny.
