As we have layers in AutoCAD Product, I Started using different sketches and using them as layers by turning the visibility on and off.
Can we write a macro (button Click) to turn one perticular Sketch on and off???
For example If I had a Sketch named as GROUNDFLOOR, can I use a macro to turn them off and on when needed??
AD
Hi AD,
Contact with API expert Jane, it possiblly to add an VBA/VB code to turn on/off the visibility of perticular Sketch, but for button provided, need more consideration.
Xun
How about runt he macro in VBA?
Sub test()
Call SetVisible(True)
End Sub
Sub SetVisible(bFlag)
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSks As PlanarSketches
Set oSks = oDoc.ComponentDefinition.Sketches
Dim oSketch As PlanarSketch
For Each oSketch In oSks
If oSketch.Name = "GROUNDSketch" Or oSketch.Name = "What I Need else" Then
oSketch.Visible = bFlag
End If
Next
End Sub
Please make sure the sketch name is what you want to turn off/on in the code line below
End If
And I think you could also use the "find button" on the top of inventor browser panel to get the right sketch, and turn on/off its visibility. Please see the attached image.
hello River,
I tried tried and tried to fix that error and it is saying as missmatch error.
Included picture if what I am doing.
If you know something abt it let me know
Based on the error in the image, it looks that you want to use this macro in assembly document. But the macro you used is only for part document. If you want to use the macro for assembly document, we should refine the macro to accomplish it.
Hi AD,
I guess you opened an assembly document, instead of part document. to make the code supports all types of document, please change the document type to Document instead of PartDocument. Use following code instead to have a try:
Sub test()
End Sub
Dim oDoc As Document
End If
Next
End Sub
And there is another comments:
If you want to change the visibllity staus of the sketches in assembly document, they the code above works.
But it won't work on the sketches of assembly occurrences. It will work in this way if you want to change the sketch status in assembly occurrences:
Sub Test()
'Input True or False
Call ChangeVisiblityOfAssySketch(True)
End Sub
Sub ChangeVisiblityOfAssySketch(bFlag)
Dim odoc As AssemblyDocument
Set odoc = ThisApplication.ActiveDocument
Dim i As Integer
Dim oSk As PlanarSketch
For i = 1 To odoc.ComponentDefinition.Occurrences.Count
For Each oSk In odoc.ComponentDefinition.Occurrences
If oSk.Name = "What you need" Then
oSk.Visible = bFlag
Exit For
End If
Next
Next
End Sub
Hi AD,
Considering the complex condition of your modeling file that I'm afraid there may be sub assembly in your assembly document, so I write another routine for you to use recrsion to foreach every sub node, here is the code, hope it helps.
'*************************Start*********************************
Sub Test()
'Rename the first parameter "MyTest" to any name of the sketch you want to control
'Input True or False to make the sketch visible or invisible
Call GetPartOccurrence("MyTest", True, oDoc)
End Sub
Function GetPartOccurrence(strSketchName As String, bFlag As Boolean, oDoc As Document) As Document
Dim i As Integer
Dim oSubDoc As Document
For i = 1 To oDoc.ComponentDefinition.Occurrences.Count
If oDoc.ComponentDefinition.Occurrences(i).Definition.Type = kAssemblyComponentDefinitionObject Then
Set oSubDoc = oDoc.ComponentDefinition.Occurrences(i).Definition.Document
Call GetPartOccurrence(strSketchName, bFlag, oSubDoc)
ElseIf oDoc.ComponentDefinition.Occurrences(i).Definition.Type = kPartComponentDefinitionObject Then
For Each oSk In oDoc.ComponentDefinition.Occurrences(i).Definition.Sketches
If oSk.Name = strSketchName Then
oSk.Visible = bFlag
Exit For
End If
Next
End If
Next
End Function
'*************************End*********************************
Hi jane,
Thanks for writing such a long code..
I'll execute today and keep you posted...
Last code works fine for me within assembly and also used changing it to part.. worked really good.
I'll post those codes to nite or in couple of day aftere some testing..
AD
Hello fanj,
I tried this macro and Working Very Fine.
I am writing another macro to trun on and off A preticular sketch which is in sub-assembly in Main assembly.
Code is running finw without errors, but sketches are not turning on.
Please have a look to the code and feel free to suggest any changes:
Sub ToggleSketchVisibilityOn()
' Set a reference to the Sketches collection. This assumes
' that a part document containing a sketch is active.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
Set oCompDef = oAsmDoc.ComponentDefinition
Dim oOcc As ComponentOccurrences
Dim oOccDoc As Document
Dim oSketchname As String
oSketchname = "F"
Dim i As Integer
For i = 1 To oCompDef.occurrences.Count
If oAsmDoc.ComponentDefinition.occurrences(i).Definition.Type = kPartComponentDefinitionObject Then
Exit Sub
Else
If oAsmDoc.ComponentDefinition.occurrences(i).Definition.Type = kAssemblyComponentDefinitionObject Then
Set oOccDoc = oAsmDoc.ComponentDefinition.occurrences(i).Definition.Document
End If
End If
Dim oSketches As PlanarSketches
Set oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
Set oSketches = oOccDoc.ComponentDefinition.Sketches
For Each oSketch In oSketches
If InStr(oSketch.name, oSketchname) Then
oSketch.Visible = True
End If
Next
Next
End Sub
Here is Solution...
Private Sub Test_SubAssemblySketches()
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = ThisApplication.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition
Set oAssyDef = oAssyDoc.ComponentDefinition
'toggle visibility of sketches in the main assembly
Dim oSk As Sketch
For Each oSk In oAssyDef.Sketches
oSk.Visible = Not oSk.Visible
Next
'process all subassemblies
For Each oOcc In oAssyDef.occurrences
If oOcc.Definition.Type = kAssemblyComponentDefinitionObject Then
Dim oDef As AssemblyComponentDefinition
Set oDef = oOcc.Definition
'toggle visibility of sketches in subassemblies
Dim oSkProxy As PlanarSketchProxy
For Each oSk In oDef.Sketches
Call oOcc.CreateGeometryProxy(oSk, oSkProxy)
oSkProxy.Visible = Not oSkProxy.Visible
Next
End If
Next 'oOcc
End Sub
For Sketches in Subassemblies, Proxy should be used....
