Inventor General Discussion
Distinguished Contributor
5 Kudos
Post 1 of 5
machaning of casting
249 Views, 4 Replies
12-09-2009 11:26 AM
Just for curiosity how are you handling the machining of a casting part? By inserting into a standard assy or by inserting into a weldment assy and using the machining features. We seem to have people doing it both ways and need to get this standardized. I can kinda see the arguments for both ways.
msk
2,122 Kudos
Post 2 of 5
Re: machaning of casting
12-09-2009 11:34 AM in reply to: msklein
If it is not a weldment, then Derive Component. Not sure why you would do in assembly if not a weldment unless match-machined with other parts.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 3 of 5
12-09-2009 06:38 PM in reply to: msklein
We build a model of the casting and then derive it in a new IPT to become the machined part. Because we often machine multiple (different) parts from the same casting, we have to go this direction. Many argue you should make the machined part first and derive the casting from it, by adding stock where needed. That doesn't work (well or cleanly) in our scenario.
Problem is, designs are made with finished parts, not cast parts.
*Dennis Jeffrey
Post 4 of 5
12-09-2009 09:13 PM in reply to: msklein
http://www.youtube.com/watch?v=1WioCqJ1nbo
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
0 Kudos
Post 5 of 5
12-10-2009 09:24 AM in reply to: msklein
Mind e-mailing me those files. I think my way might be simpler, accomplish the same result, and have one less file to keep track of.
