Inventor Forum
Louver Punch
4 REPLIES 4
jfleeger
5041 Views, 4 Replies
Louver Punch
Has anyone used the cbliss Louver Punch (http://www.cbliss.com/inventor/iFeatures/index.htm) with Inventor 2012?
Everytime I try I get an error: "The file has 0 Hole Centers in its Interface Sketch. To be a valid Template, the Interface Sketch must contain exactly 1 Hole Center"
It worked fine in 2010.
Any Idea how to resolve this error?
4 REPLIES 4
xiaoyan.qi
in reply to: jfleeger
Hi, Thanks for your post
you can use the Insert iFeature command to insert the "Punch" (Manage tab->Insert iFeature)
in inventor, iFeature and Punch are both iFeature, but there are some difference between them on creating and using. for punch tool, when you create it, you need contain a center mark in the sketch, so when you try to insert punch tool, you need to create a sketch and add center point in the sketch. but it's not required on iFeature.
Hope it's helpful
Mick
jfleeger
in reply to: xiaoyan.qi
I want to know why the Punch I used successfully in IV 2010 doesn't work in 2012, or how to fix it.
I downloaded the Punch from cbliss, saved it in my Punches folder, migrated it to 2012. Created a sheetmetal part, created a sketch with a pattern of center points and then tried to use the punch.
This is the exact same procedure I used successfully in 2010.
If Punch would work, I would be able to insert the features I need with one sketch and one Punch.
If I were to have to use iFeature, it would take two iFeatures and two feature patterns.
BTW I did find a work around, I was able to copy and modify a part that I had created with IV 2010 that used this punch.
Mike_Maenpaa
There are two on http://www.cbliss.com/inventor/iFeatures/index.htm
Which one are you using, Louver.ide or LouvrePunch.ide?
Mike
jfleeger
in reply to: Mike_Maenpaa
Thank you for making me feel like an idiot. Sorry I wasted everyone's time. I was using the wrong one.
