I recently started panning around and zooming around my main body (a house im building for school) and I zoomed out to far and i cannot find the house anywhere. Is there a way to go back to the house? I am freaking out
Solved by Cadmanto. Go to Solution.
Welcome to the forum.
Or you can do this as well.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
There is still a Zoom All under the view tab in Fusion.
You are in the wrong forum.
Inventor Fusion is not Autodesk Inventor
http://forums.autodesk.com/t5/Inventor-Fusion/bd-p/370
Fusion is not inventor (YET) :). Middle mouse works in Inventor, for Fusion the setup is different, youll have to use the view all.
