Good day all
When generating a detailed view from a section view, the hatch lines stay the same distance apart.
Therefore I always go in and change the scale to a smaller scale on the detail view.
However on any editing of the main view, the hatch pattern scale on the detailed view reverts back to the same as the main view and has to be redone over again.
Is there any way of fixing this hatch pattern scale on the detail view so that it doesn't ever change
Mike Kovacik
Alutip
(Aluminium Truck Load Body Manufacturers)
Pretoria
South Africa
Hi Mike,
You probably can change this with a iLogic rule / program
I have seen iLogic rules to change colors of the hatches so the scale of the hatches should be adjustable too.
Hi Mike,
I have looked in the Inventor Customization groups for the code I mentioned, but it I cannot find anyting about it now..
