I build a hopper as demonstrated in the utube video and everything worked great. But after I checked it into vault it lost its adaptivity.
Why and is there an easy way to get it to adapt again.
I went throught each part and fixed it but as soon as I change the size of the skeleton it doesn't update.
After reviewing the video there is a possibility that you may have opened the incorrect file from vault as just checking a file into Vault should not remove adaptivy.
As the video showed you are creating multiple files with multiple steps.
As to your question on turn adaptivity back on it’s not as easy as that and one of the reason that led me to believe the incorrect file was opened.
