Inventor Forum
Looking for material properties for grey iron
1 REPLY 1
689 Views, 1 Reply
I would like to add grey iron to my material properties.
Please has anyone got a list of the properties of C/I or sterr me in the right direction to find the properties in a single source?
1 REPLY 1
------=_NextPart_001_002B_01C2F53F.88D83250
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
First if all, apologies for the HTML for those of you who can't view it =
- maybe you should get a better newsreader 😉
www.matweb.com
Lists grey cast iron as :-
Subcategory: Gray Cast Iron; Metal
Key Words: Grey Cast Iron, ASTM A 48 Class 40, cast irons
Component Wt. % =20
=20
=20
C 3.25 - 3.5 =20
Cr 0.05 - 0.45 =20
Cu 0.15 - 0.4 =20
Component Wt. % =20
=20
=20
Mn 0.5 - 0.9 =20
Mo 0.05 - 0.1 =20
Ni 0.05 - 0.2 =20
Component Wt. % =20
=20
=20
P Max 0.12 =20
S Max 0.15 =20
Si 1.8 - 2.3 =20
=20
Material Notes:=20
Carbon listed in the composition above is the total carbon. Can be oil =
quench hardened from 860=B0C to attain a Rockwell C 50 minimum surface =
hardness. Data provided by the manufacturer, Siltin Industries, Inc.
Click here to view available vendors for this material.
Physical Properties Metric English Comments=20
=20
=20
Density 7.15 g/cc 0.258 lb/in=B3 Typical for Gray Cast Iron=20
Mechanical Properties=20
=20
=20
Hardness, Brinell 183 - 234 183 - 234 =20
Hardness, Knoop 258 258 Converted from Brinell hardness.=20
Hardness, Rockwell B 97 97 Converted from Brinell hardness.=20
Hardness, Rockwell C 20 20 Converted from Brinell hardness.=20
Hardness, Vickers 246 246 Converted from Brinell hardness.=20
Tensile Strength, Ultimate Min 276 MPa Min 40000 psi =20
Ultimate Compressive Strength Min 1034 MPa Min 150000 psi =20
Machinability 0 % 0 % Very good machinability. No numerical =
rating available=20
Hope this helps
Rory
Content-Type: text/html;
charset=3Diso-8859-1">
First if all, apologies for the HTML =
for those of=20
you who can't view it - maybe you should get a better newsreader =
Component    Wt.=20
src=3D"http://www.matweb.com/images/spacer.gif" =
width=3D20>
background=3D/images/line.gif border=3D0>
src=3D"http://www.matweb.com/images/spacer.gif"=20
width=3D1>
C 3.25 - 3.5
Cr 0.05 - 0.45
Cu 0.15 - 0.4
Component    Wt.=20
width=3D20>
width=3D1>
Mn 0.5 - 0.9
Mo 0.05 - 0.1
Ni 0.05 - 0.2
Component    Wt.=20
width=3D20>
width=3D1>
P Max 0.12
S Max 0.15
Si 1.8 - 2.3
Material Notes:
Carbon listed =
in the=20
composition above is the total carbon. Can be oil quench hardened from =
860=B0C to=20
attain a Rockwell C 50 minimum surface hardness. Data provided by the=20
href=3D"http://www.matweb.com/search/GetVendors.asp?bassnum=3DDSI001">=
Click=20
here
border=3D0>
width=3D1>
Density =
href=3D"http://www.matweb.com/search/GetUnits.asp?convertfrom=3D43&va=
lue=3D7.15">7.15 g/c...
size=3D-1>0.258 lb/in=B3  Typical for =
Gray Cast=20
Iron
Mechanical =
Properties
width=3D1>
Hardness, =
Brinell
183 - =
234
183 - =
234
  size=3D-1>
Hardness, Knoop size=3D-1>258 size=3D-1>258  Converted from =
Brinell=20
hardness.
Hardness, Rockwell =
B
97 97  Converted from =
Brinell=20
hardness.
C
20 20  Converted from =
Brinell=20
hardness.
Hardness, =
Vickers
size=3D-1>246 size=3D-1>246  Converted from =
Brinell=20
hardness.
Tensile Strength, =
Ultimate
href=3D"http://www.matweb.com/search/GetUnits.asp?convertfrom=3D109&v=
alue=3D276">Min=20
Min=20
40000 psi
  size=3D-1>
Ultimate Compressive=20
Strength
alue=3D1034">Min=20
Min=20
150000 psi
  size=3D-1>
Machinability size=3D-1>0 % size=3D-1>0 %  Very good =
machinability. No=20
numerical rating =
available
Hope this helps
Rory
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: =
0px">
------=_NextPart_001_002B_01C2F53F.88D83250--
