Inventor Forum
Looking for guidance on hardware (true server vs workstation for host).
4 REPLIES 4
SHCS
357 Views, 4 Replies
Greetings. First post. Hopefully someone can offer some quick guidance.
A client has come to me for guidance on something that’s a little out of my area of experience. They are implementing an Autodesk Inventor installation that will work in conjunction with a custom front end they've built. Essentially they've built a front end which will interface with an SQL database to compile a list of components for a made to order item. Their front end will then pass the information on to Inventor for rendering and printing. The front ends will be on client stations. Inventor will be installed on a dedicated system running essentially Inventor and SQL, nothing else.
In my talks with them they've been repeated dropping the 'Server' word. And it is their understanding that we need a full blown server to run this. From everything I've read a high end Workstation with appropriate graphics (Quadro or high end Direct 3D) would suffice.
In fact, as far as I can see, the recommended system spec don't include any of the Server OSs. I'm thinking that may have answered my question right there. We know the hardware specs we need, the client admirably is planning to over purchase as far as hardware goes. We know we'll benefit from workstation graphics. The question is 'True Server with Server OS' or Workstation running Win 7/Win 8 to host.
Question One: Anyone have any experience with this kind of Client / Server setup. Any insight on the Server vs Workstation option would be appreciated.
Question Two: In the past when looking for custom systems for specific purposes (video editing comes to mind) I've been able to find online vendors specializing in specifically that area. I've only found one such vendor for Inventor and they're in the UK. Does anyone know of any North American vendor specializing in systems specifically geared to work well with Autodesk products. I'd prefer to pass this client on to a vendor with exactly the experience he's looking for then botch any recommendations myself.
Thank you in advance for any insight any of you may give.
4 REPLIES 4
DarrenP
in reply to: SHCS
are you talking about Citrix? if yes IMSCAD (U.K based) are the only ones that i know of that tests this with autodesk products
DarrenP
dgorsman
in reply to: SHCS
Technically may be feasable - we can install SQL Server on a workstation and run various software from it.  Depending on the number of users hitting up the SQL Server database, you may very well need a full-on server complete with multiple processors *and* SQL Server licensing to match.
But if I'm reading that right you may have bigger problems.  First, Inventor isn't built to run on s a server OS (SQL Server is) and isn't supported in that environment.  Second, running a remote session of Inventor on a "server" (workstation or otherwise) from a users desktop could very well be a EULA violation.
SHCS
in reply to: SHCS
Thank you guys for your insights. I appreciate your quick responses.
I was able to locate a consultant familiar with both Inventor/SQL and hardware options. I passed the client on to him as what the client was requesting was a little out of my area of experience.
That being said, I'll pass your comments about the EULA on to him.
swalton
in reply to: SHCS
I've never used it, but this sounds like Inventor ETO.
http://www.autodesk.com/products/inventor-engineer-to-order/overview
You might have your customer take a look at this tool too.
Another choice might be to have the engineers use plain Inventor, and store the designs in Vault.  Then the front end aplication can pull the needed data from the Vault server.  Maybe they can use the Vault Job Processor to generate the manufacturing files and renders.
Steve Walton
Inventor 2023
Vault Professional 2023
