Inventor General Discussion
Valued Contributor
recordsj
Message 1 of 19 (471 Views)
long time to execute undo or redo command Inventor 2012 sp2
471 Views, 18 Replies
01-15-2013 03:50 PM
I am running Inventor 2012 sp2.
Even with a simple IPT that only has a handfull of features, at times it takes a long time (3-5 minutes, sometimes longer) for Inventor to execute a undo or redo command.
Undo file size setting in Application options is set at 1MB (which is teh same setting I used in previous versions).
I haven't seen this issue before, but now after a receint upgrade to Invetor 2012 from 2010, I am now seeing an issue there.
Any fixes?
Employee
stanislav.sedlak
Message 2 of 19 (460 Views)
Re: long time to execute undo or redo command Inventor 2012 sp2
01-15-2013 11:51 PM in reply to: recordsj
Could you attach the part file for further investigation?
Stanislav
Valued Contributor
recordsj
Message 3 of 19 (438 Views)
01-16-2013 07:22 AM in reply to: stanislav.sedlak
the issue hasn't been file specific, I have had this issue occur on a lot of files.  Other people I work with have been experiencing the same issue.
-niels-
Message 4 of 19 (432 Views)
01-16-2013 07:48 AM in reply to: recordsj
Is it really at 1 MB or is that a typo?
We have our undo file size set to 1024 MB so inventor actually has some memory to undo stuff.
Does the speed improve if you increase your setting?
(i believe the default was 256)
Using IV2014 Pro SP2 - upd.1, Win7-64bit
Valued Contributor
recordsj
Message 5 of 19 (426 Views)
01-16-2013 07:53 AM in reply to: recordsj
It is at 1024 MB.  See screenshot below
-niels-
Message 6 of 19 (420 Views)
01-16-2013 07:59 AM in reply to: recordsj
ah ok, typo...
Anyway, do you see any difference when you change that size (up or down)?
Could there be anything else interfering, like antivirus or such?
I'm on 2013, never used sp2 for 2012... so can't say if it could be related to that...
Curtis_Waguespack
Message 7 of 19 (411 Views)
01-16-2013 09:02 AM in reply to: recordsj
Hi recordsj,
Just a thought, but if you go to the Tools tab > Application Options button > File tab and look at the Undo file location option, you might try changing that to a different location (network location vs. local location) to see if that changes anything.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
recordsj
Message 8 of 19 (408 Views)
01-16-2013 09:07 AM in reply to: Curtis_Waguespack
It is already pointing to a local folder on the hard drive for the undo.
jfleeger
Message 9 of 19 (364 Views)
02-07-2013 10:17 AM in reply to: recordsj
Are you using ctrl+Z and ctrl+Y to undo and re-do, or are you using the menu icons?  I have noticed that some commands take longer with the keyboard than with the menu for some reason.  I'm not sure what service pack it started with; but it is definatly something I see in 2012.
Valued Contributor
recordsj
Message 10 of 19 (362 Views)
02-07-2013 10:20 AM in reply to: jfleeger
I use the menu icons.
