I've firstly reported wrong translation of "Each"value of Base Unit (Структурная единица) in Russian Inventor* (as well as in Vault) almost three years ago.
For we it took opening series of cases to get some improvenents regarding this issue (#06585616, #06589490, #07707724...etc)
Regarding Inventor there was hotfix (dll) for Inventor 2012 produced and provided "specially for our company" and public Russian translation hotfix for Inventor 2013 (if I'm not mistaken this one http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/localizatio...).
Recently we moved to Inventor 2014.
And "here it is again" - we again have wrong translation of Base Unit:
I wonder should I create separate case for each release (2014, 2015, 2016 ....) in order translation be fixed once and forever?
* Translated as "Все" while should be "шт.".
** Inventor 2014 SP1 Update3 is used
Solved by -niels-. Go to Solution.
We have tried communicating with several local resellers in the past (if case occured a bit harder then "easy" - the experience was always negative).
They are all "innocent" (don't know software deep enough). Thus we don't want to waste our time on local resellers anymore. I believe this is also typical for other customers (saw alike situation described somewhere here regarding German resellers).
I was pretty sure global standard for making request is common for all regions, isn't it?.
You post you problem here and if you don't mark it as solved within couple days you are get contacted (if you on subscription).
Anyway they finally let me know they've passed issue to developers a week ago (i wish I get automatic e-mail notification about the fact but I haven't).
The problem has been verified by our development team as I informed you a week ago in the Saleseforce case. They are preparing a new hotfix which should be available by the end of this week on our WEB site.
In case of reporting issues like that, the best thing is to submit a regular case via Saleseforce so that Product support can check it immediately and notify development about that. Posting this on the forum takes some time until it gets to product support.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks.
But there are two issues with it:
1. I can't download neither of four files (tried IE and Google
Chrome) ... Wonder is it my local problem or some kind of broken link....
2. Nobody notified me that it was published 7 days ago....
Niels van der Veer
The Netherlands
I just checked the support page again and it's been fixed, now you can download the hotfix.
Be sure to read the readme, it advises to make a backup of a .dll file.
Niels van der Veer
The Netherlands
