Inventor Forum
Logo problem when exporting & printing to PDF-SP2 Bug?
31 REPLIES 31
Message 1 of 32
gcross
5188 Views, 31 Replies
Just after installing SP2 update I noticed that PDF files newly created from an IDW no longer will show our logo graphc (BMP file) at all.
I tried printing to Adobe PDF from Inventor & the logo graphic comes out looking extremely poor (see images attached).
I have been exporting  these identical files to PDF for a long time & the logo has not been a problem. We did not change the logo file.
This is a major problem.
Is there a setting that I have overlooked perhaps? Anything else that would cause this?
Thanks.
Gary
Tags (4)
31 REPLIES 31
Message 21 of 32
DOSE IT WORK ????
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 22 of 32
Yes worked fine - tested with export to PDF & DWF, for embedded images & tables. Should be live for download today.
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 23 of 32
BrandonBG
in reply to: ChrisMitchell01
Message 24 of 32
ChrisMitchell01
in reply to: BrandonBG
Thanks for confirming, Brandon.
Sorry for the inconvenience.
Chris
Chris Mitchell
Autodesk, Inc.
Message 25 of 32
spackle42
Thanks for getting this sorted Chris.
Justin Smith
Inventor Pro 2015 SP1
HP Z400 Workstation
Intel Xeon W3565 @ 3.20GHz
12Gb RAM
Win 7 64 Pro SP1
Spacepilot Pro v3.17.4
Message 26 of 32
Rich.O.3d
in reply to: spackle42
Thanks Chris
Installed hotfix and now Export to PDF is working fine.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 27 of 32
torishaver
in reply to: gcross
All of a sudden I cannot print or export a file to pdf.  When I do it does not appear as an engineering drawing.  The lines appear as if drawn with a fat marker.  Text and dimension lines do not appear.  I opened one of your sample drawings that came with Autocad and it did the same thing.  Therefore, I am concerned that something is corrupt in Autocad or a setting has changed on software launch.
Message 28 of 32
torishaver
in reply to: torishaver
Here is a sample of the pdf export
Message 29 of 32
johnsonshiue
Hi! Did you just install R2014 SP2? If yes, it is a known issue which has been fixed by a followed-up hotfix.
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/hotfix-inv1...
Please install it on top of R2014 SP2 and the problem should go away. If you still see the behavior, please let me know asap.
Many thanks!
Software Test Engineer
Message 30 of 32
HI,
 I just tried installing INV18202, it gets past the point of the credentail tiles and then goes into a fatal error. It says the instilation ended prematurely do to a fatal error? how can i get it to install?
Message 31 of 32
If you look in your %temp% folder there may be an installation log file from this failure; do you have that file & does it contain any info to help debug the problem?
Chris
Chris Mitchell
Autodesk, Inc.
Message 32 of 32
 I couldn't find a log file under the %Temp% folder. I did find the INV18271 Fix and was able to get it installed. I just tried out exporting an IDW to PDF with embeded company logo and it works great!.
Kyle
