What file format would work with both Inventor and autocad? I have an embedded logo of a bmp in my Inventor template but it does not show up in autocad.
Thanks.
.dwg will work in both. I believe that if you create your logo in a .dwg format and save it as a block, you can bring that same block into an Inventor .idw.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
We have used PNG and JPEG images (as well as AutoCAD blocks). Just making sure the image files are not linked.
