Inventor General Discussion
tbitting
Message 1 of 5 (147 Views)
Lofting with rails
147 Views, 4 Replies
04-16-2012 12:34 PM
Hi all,
I have a part that I'm trying to loft using 3d sketches for the rails will this work? Everything is fine till I try to add the rails, As you can see the loft works with out the rails.
Thanks for looking
Tim Bitting
Windows 7 x64
IV 2012
Your rail curves are not smooth (tangent) as indicated by the error message.
Therefore either add appropriate fillets or do a spline if that gets your design intent
or
if your design intent is straight lines as you have your rails - then simply do two lofts.
JDMather
Message 2 of 5 (136 Views)
Re: Lofting with rails
04-16-2012 01:30 PM in reply to: tbitting
or
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
tbitting
Message 3 of 5 (128 Views)
04-16-2012 01:46 PM in reply to: JDMather
Thanks JD. that will work for what I need on this. But if I need to, where would I add fillets?
Tim Bitting
Windows 7 x64
IV 2012
JDMather
Message 4 of 5 (123 Views)
04-16-2012 01:55 PM in reply to: tbitting
At the intersections of the  lines in  your 3D sketch. (Bends in 3D sketch)
But actually - I almost never ever create a 3D sketch as you have.
Nearly all of my 3D sketches are a result of Intersection Curve of 2D sketches.
Much easier to control and edit.
So, I would have had a Front and Side (in your case) 2D sketches with fillet constrained in one or the other (depending on design intent) to Sketch8, then found the 3D intersecting curve.
Yours is a simpler case of the 3D sketch in the Vacuum tutorial in my signature.
tbitting
Message 5 of 5 (112 Views)
04-16-2012 03:46 PM in reply to: JDMather
Ok I've seen the vacuum  part before, I'll have to go back and review, it's been awhile.
Thanks again.
Tim Bitting
Windows 7 x64
IV 2012
