Inventor Forum
Lofting with rails
4 REPLIES 4
tbitting
465 Views, 4 Replies
Lofting with rails
Hi all,
I have a part that I'm trying to loft using 3d sketches for the rails will this work? Everything is fine till I try to add the rails, As you can see the loft works with out the rails.
Thanks for looking
Tim Bitting
Windows 7 x64
IV 2012
4 REPLIES 4
JDMather
in reply to: tbitting
Your rail curves are not smooth (tangent) as indicated by the error message.
Therefore either add appropriate fillets or do a spline if that gets your design intent
or
if your design intent is straight lines as you have your rails - then simply do two lofts.
tbitting
in reply to: JDMather
Thanks JD. that will work for what I need on this. But if I need to, where would I add fillets?
Tim Bitting
Windows 7 x64
IV 2012
JDMather
At the intersections of the  lines in  your 3D sketch. (Bends in 3D sketch)
But actually - I almost never ever create a 3D sketch as you have.
Nearly all of my 3D sketches are a result of Intersection Curve of 2D sketches.
Much easier to control and edit.
So, I would have had a Front and Side (in your case) 2D sketches with fillet constrained in one or the other (depending on design intent) to Sketch8, then found the 3D intersecting curve.
Yours is a simpler case of the 3D sketch in the Vacuum tutorial in my signature.
tbitting
Ok I've seen the vacuum  part before, I'll have to go back and review, it's been awhile.
Thanks again.
Tim Bitting
Windows 7 x64
IV 2012
