In article <859F087A70A3AE483115809486BA2612@in.WebX.maYIadrTaRb>,
hoser_71@yahoo.com says...
> I just looked at the loft and the only problem was that you had too much
> geometry on your rail sketch. To get around this I created a new sketch and
> projected up only the geometry for the rail. I posted my file on the CF for
> you to look at. I was then able to pick all of the loft sections and the
> one rail and finish it in one loft feature.
Hey! They you go. I knew there was a "trick". Being that when selecting
the profiles, of there's multiple loops you need to pick twice
sometimes, it also appeared to me that when selecting the rail, a double
pick was one order, once to select the "sketch" and the other time to
select the profile in the sketch.
I tried what you suggested in In and omitted the center profiles, using
only those at the beginning and end of each arc and it worked like a
charm.
I also tried the same thing in 6 (the production version here) and as
someone pointed out yesterday, a rail at each place where your lofted
profiles has an entity touching another is in order.
> I'ld enjoy seeing some of the stuff you do at one of the Minnesota Inventor
> user group meetings.
Being that's it's granite, I don't know that I could lug in any pieces.
Might be a bit heavy. 😉
We do a lot of stuff here. Cemetery memorials, mausoleums, granite for
industrial applications, structural cladding/building facing, paving,
etc.
The profile you saw going to end up being wall cap for a wall at the
Visitors Center of the US Capital. If you ever get to Nashville, in
front
of their state capital is a state bicentennial plaza with a lot of
granite provided by us. Part of that is a 200 foot map of Tennessee
(complete with city/county names, lakes, rivers, etc.) all paved out of
granite. FDR Memorial in Washington DC was done by us as well.
Most of the work here doesn't involve 3d. Inventor so far hasn't been
used (mainly MDT) for the 3d work and I'm working on getting people
switched over to Inventor. Things like curved staircase, etc where the
piece ends up ramping and twisting is a prime candidate for 3d.
Didn't realize you were local to the area. You'll have to introduce
yourself at the next user group meeting. I haven't hit them regularly in
a while but I do go. Perhaps you've noticed the long haired redhead.
That would
be me.
Darren J. Young
CAD/CAM Systems Developer
Cold Spring Granite Company
202 South Third Avenue
Cold Spring, Minnesota 56320
Email: dyoung@coldspringgranite.com
Phone: (320) 685-5045
Fax: (320) 685-5052
Darren J. Young
Fax: (320) 685-5052
