Inventor General Discussion
Member
0 Kudos
Post 1 of 6
Accepted Solution
Lofting/extruding to a point, along a curve?
447 Views, 5 Replies
07-15-2012 08:13 PM
Hi all, fairly new user here. Coming from Sketchup to real big boy tools. I watched the tutorial videos and tried poking around a bit for this specific answer but came up a bit short.
What I'm trying to do is loft a face to a point. Easy enough. I've got my point established on an offset work plane, and I can just loft to that, however, I get nothing but straight lines. (First attachment)
An example of the ideal outcome in SketchUp is the second attachment.
I'm having the most difficulty trying to draw the curves along which I want the face to be lofted because, even as I sketch along my 2D plane, I can't snap the endpoints of my arcs to the endpoints of the face (or the point to which they'll all connect). Can I get some tips as to how to make this happen? File in progress attached.
Hi djsoundcrafter,
You can use the Project Geometry tool to bring geometry in from existing sketches. So if you create a sketch on an origin plane running perpendicular to the base sketch, you can then use Project Geometry to pull in the corner of the base sketch as point from which you can constrain the rail sketches.
I hope this helps.
Curtis
*Expert Elite*
2,129 Kudos
Post 2 of 6
Re: Lofting/extruding to a point, along a curve?
07-16-2012 04:31 AM in reply to: djsoundcrafter
Blade Base sketch is not constrained.  You might start here.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Point Plane is not needed.
You do not have a sketch point to loft to.
You do not have any Rails (guide curves).
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Expert Elite*
2,129 Kudos
Post 3 of 6
07-16-2012 05:12 AM in reply to: JDMather
Don't look at this till you have gone through the Help>Learning Tools>Tutorials and the pdf I linked previously.
Member
0 Kudos
Post 4 of 6
07-17-2012 07:51 AM in reply to: JDMather
What's the key to drawing the guide rails? Since they're perpendicular to the base plane, how can I fix their starting points to it? I didn't seem to find this in tutorials.
*Expert Elite*
1,705 Kudos
Post 5 of 6
07-17-2012 08:07 AM in reply to: djsoundcrafter
Hi djsoundcrafter,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
0 Kudos
Post 6 of 6
07-17-2012 08:13 AM in reply to: Curtis_Waguespack
Awesome, thanks very much, Curtis, and JD for your useful tutorial!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
