Inventor General Discussion
Member
0 Kudos
Post 1 of 14
Accepted Solution
Lofted surface transition
356 Views, 13 Replies
05-01-2012 04:40 PM
When creating a loft between two curves, I am not able to control the top and bottom portion of the surface created, I have joined a picture of the part and my IPT file with the problem I got.
Thank you for your help.
Daniel P,
Finally got it with JD's recommandations.
Thank you very much.
Daniel P.
48 Kudos
Post 2 of 14
Re: Lofted surface transition
05-02-2012 12:19 AM in reply to: daniel.pinsonneault
Don't loft, rather sweep the two profiles, and then shell them to obtain the correct thickness.
6 Kudos
Post 3 of 14
05-02-2012 04:45 AM in reply to: daniel.pinsonneault
Hi Daniel,
please find a sample of the desired part attached. It was build with the 2009 Version of Inventor so you should be able to open it.
cheers
Matthias
Nihil Ex Nihilo
Member
0 Kudos
Post 4 of 14
05-02-2012 04:57 AM in reply to: daniel.pinsonneault
Thank you for your solution, but in my part there are three differents sketchs at each end and the top of the part is not flat. That's why I used surfaces to create the curved top.
Thank you.
Employee
194 Kudos
Post 5 of 14
05-02-2012 06:13 AM in reply to: daniel.pinsonneault
Daniel,
I took a quick look at the model. I personally think this can be done easily by extruding a Y-shape profile. Then draft side faces. Would it work better?
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
*Expert Elite*
2,126 Kudos
Post 6 of 14
05-02-2012 06:30 AM in reply to: daniel.pinsonneault
Here is a quick attempt.
I think I would use some 3D intersection rails to get it correct.
Your sketches were too complicated for me - edit your first sketch and see how I simplified it.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
48 Kudos
Post 7 of 14
05-02-2012 06:36 AM in reply to: daniel.pinsonneault
See attached attempt. The surface looks OK, but I cannot make a solid of it.
*Expert Elite*
2,126 Kudos
Post 8 of 14
05-02-2012 06:42 AM in reply to: JDMather
Here is another attempt.
I might use this as a guide to start over.
*Expert Elite*
2,126 Kudos
Post 9 of 14
05-02-2012 06:50 AM in reply to: JDMather
And a variation on Walter's - but I didn't really like the fillets.
*Expert Elite*
2,126 Kudos
Post 10 of 14
05-02-2012 01:33 PM in reply to: JDMather
Any progress on this?
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
